  • 3 voto(i) - 4.33 media
Prius Prime - V4 plug-in
Apro la discussione, per raccogliere qui tutte le informazioni che riusciremo a recuperare.
Anche oggi TMI, sulla pagina facebook, si è sbilanciata sulla prossima uscita della versione plug-in
Attendiamo fiduciosi  Yes
http://www.hybridcars.com/how-much-electric-range-does-the-new-toyota-prius-plug-in-need-to-be-competitive/
Citazione:
Fushiki suggested Toyota does not wish to compromise interior space by stuffing more batteries in the trunk, or other passenger space, but it has looked at work-arounds for this dilemma.
“For the new Prius, we moved the battery from under the luggage space to under the rear seats. To install a battery in a limited space, we reduced cell size and improved storability,” said Fushiki of the regular Prius. “We are still considering how to lay out the battery in the next Prius PHV. It is possible that the battery, whose capacity will be larger than that of the new Prius’ battery, will be stored in the center console or luggage space.”
In order to facilitate all-electric driving, Fushiki commented also on the upgrades to the powertrain that will distinguish the PHV.
“To ensure EV driving performance, we will employ a lithium-ion (li-ion) battery and motor that are different from those of the new Prius,” he said. “The li-ion battery of the new Prius is focused on output density. Because EV driving will be prioritized for the next Prius PHV, we are currently developing a battery with a focus on energy density. Also, we will employ a drive motor larger than that of the new Prius.”
Autonet.tw was also correct in the JC08 fuel economy later revealed for the Prius Eco version, but it over-estimated electric motor power and total system horsepower, so were some its unequivocal statements nothing but guesswork?
In its comments about the Prius PHV, it boldly declared it will get 50 km range under Japan’s exceedingly easy going JC08 cycle, which might mean 21-22 miles by the U.S. EPA.
............continua
  • Nicholas
Riassumendo:
- batteria agli ioni di litio, ma ottimizzata per la densità di energia anziché per la potenza erogabile, e ovviamente più grossa di quella della Prius standard
- ancora non sanno dove metteranno questa batteria; l'articolo è di 2 mesi fa ma vuol dire che l'uscita è tutt'altro che vicina
- motore elettrico più grosso di quello della Prius standard
- autonomia reale in EV intorno ai 30-35 km, rispetto ai 20 km dell'attuale
  • aleraga84
Sempre nel link si parla di 2017
A luglio avevo letto questo :
http://www.greenstyle.it/toyota-prius-pl...61794.html
Yes Prius Plugin Silver Met Yes
Diffuso da Toyota un teaser del posteriore di una nuova versione Prius.
Sarà la Plug-In o cosa ? In effetti sembra parecchio diversa dalla Prius IV.
Che ne dite ?
http://www.quattroruote.it/news/novita/2...gamma.html
  • MMARCO
https://tapatalk.com/shareLink?url=http%...are_type=t
New Prius model NYC auto show
Mi hai preceduto....su Priuschat si parla di nuova Plug-in
A prima vista, però, non vedo lo sportellino della presa di ricarica .
In ogni caso aveva allora ragione TMI quando - protestando per la mancanza a listino in Italia del tetto apribile - mi rispose di aspettare a breve delle interessanti novità !!
Cavoli ma che ci voleva a fare i fari così? Certo sembrano un pò Honda ma almeno sono decenti.
Perché secondo voi hanno scelto due linee di design diverse?
(15-03-2016, 04:36 )nox1111-52 Ha scritto: Cavoli ma che ci voleva a fare i fari così? Certo sembrano un pò Honda ma almeno sono decenti.
Sarò fuori dal coro ma a me piacciono anche quelli a virgola dell'attuale... Li ho visti la sera e sono incredibili, fanno molto effetto e fanno sembrare l'auto diversa da tutte le altre...
  Toyota Prius MY2018 teo46 201 19.532 16-02-2018, 06:45
  Toyota C-HR -  A quando una Toyota C-HR Plug-In ? Marcos11 23 2.146 13-01-2018, 10:33
  Toyota prius + 2018 teo46 2 963 21-12-2017, 11:37
  Kia Niro Plug-in lupo_alberto 46 11.526 29-11-2017, 06:13
  Auris 2018 plug-in claudio0969 20 6.062 03-08-2017, 05:05
  Prius V4 Specifiche Europee Maxwell61 388 74.583 09-06-2017, 04:04
  Futuro prossimo ... Plug-In ! Marcos11 35 5.454 17-05-2017, 10:42
  Lamborghini urus ibrido plug in arabykola 0 732 05-01-2017, 08:17
